Bridge fog light switch?
(In Topic #99800)
Hi guys i'm after some help please,
The rear foglight on my cabby isn't working and its coming up to mot time. At first i thought it was just a bulb which i changed still didn't work checked the fuse which was ok but was 20A instead of 10A so put the right one in. If i run power to the connection in the boot the fog comes on so i know its not the light itself. I have no power at the fuse when the switch is on also the yellow light on the switch isn't on either which has made me think i have a faulty switch.
What i want to know is can you bridge the wires on the rear of the switch to bypass it to check if its faulty and if so which ones?
Thanks Steve
Thanks Steve
Totally daft question:- your testing the fog light with the dipped beam switched on? :roll:
Yep…
Thanks for the reply chudd, no relay fitted and fuse is in a seperate holder on top of fusebox. There's a few wires on the back of the switch and it still illuminates when the lights are on but still no yellow warning light, do you know if it has 2 feeds?
