Brake lights not working. Any help please??
(In Topic #130122)
So I checked the switch attached to the cyclinder and one of the prongs had snapped off. Replaced it and it still doesn't work. I've connected the part of the block that attaches to the prongs that snapped off to the battery and the light come on, all the earthing and connections to light cluster is ok so am now at a bit of a loss.
Help.
In Dorset, a "technical" usually involves bailer twine and a lump hammer…….
If you unplug the connector and short the two pins, your brake lights should come on. If they do your switch is faulty, if they don't then you have other wiring issues.
I think it is also possible for the switch to misbehave if there is a bit of air trapped behind it.
switch
Alvie said
Have you tried bridging the connector on the switch?
i have a switch if it turns out to be that !!
90 gti cabby
2001 vw t4 2.5tdi
98 passat 2.8 syncro
96 golf 1.8 gti
2011golf gt tdi
2001 vw t4 2.5tdi
96 golf 1.8 gti
2011golf gt tdi
Suggestions??
You might get away with loosening the switch, carefully pushing a bit of fluid out of the thread and then screwing the switch back in. Obviously a small travel of the pedal will generate fairly high pressure, so using the switch as a bleed nipple might not be the safest way to do it.
Or, maybe take the switch out, fill the hole to the neck with brake fluid and then put the switch back in.
Also possible that the new switch doesn't work / is the wrong type. I'm afraid don't know if there are different types, but I would guess not.
So no trapped air, all switches work, but they needed replacing anyway so doesn't matter.
Moral of the story. Always check the fuses first if you have an electrical problem.
