brake lights help pls
(In Topic #136792)
1982 cab 1.8 gti
brakes
lights
lights
I think it should have 2 switches anyway, for each of the dual circuit hydraulics?
light
l
paul_c said
Yeah its not a complicated circuit - some power, switch, brake lights. The switch is faulty, so needs replacing. The problem is, them pressure switches need the brake system bleeding after replacement…which is a pain.
so where is the other switch then pls?
I had 2 switches but binned one of them off.
Both switches on the master cylinder, one for each circuit.
Web Team
Web Team
