Blaupunkt Hamburg wiring diagram/spec Installation
(In Topic #144745)
I recently picked up a Blaupunkt Hamburg that I am wanting to get installed into my 1981 MK1 which has the early fusebox.
Has anyone got any useful links/posts that would help me get this installed?
I was hoping that I might be able to find a scan of the stereo brochure, but I cant find one anywhere.
There is no existing wiring in the car for a stereo that I can see, so it looks like im going to have to do this from scratch.
So any help would be appreciated
Also there is no aerial, so I was wondering what the best thing to do is? can you get a dash areal or something that sits inside the car, rather than needing an external one fitting.
Front of the stereo:
Back of the stereo:
Use the schematic for your connection as your set has only one speaker feed.
The owners manual is for a Hamburg with 2 x speaker feeds and there is an additional negative connection above the positive that will be absent on yours, otherwise they are both identical in operation.
I'm no auto-spark, get someone who is to confirm your set matches these diagrams before you start messing about!
Life Member
I got the wiring from Blaupunkt Direct. They had to order it but at least the connections should be fine.
Or if your a cheapskate… Radio Museum
Are there any internal options?
