Battery warning light/lamp not woking.
(In Topic #126594)
Just kidding, try the main earth lead from the battery for a start off.
~Madferret
Mk1 1457cc 5door GX '83
Thanks for the heads up dudes.
BiG_J said
Update: Problem solved, the exciter wire was disconnected! Dah! However while engine is running the battery only reads 13.3 volts and not 14.4?? What can this be the cause of?
Where is the exciter cable located? I suspect I have the same problem?
Is it wire behind the dials or on the back of the dials themselves?
Nope, its the little wire on the alternator (should be blue). It could be a break or disconnection further along.
