battery relocation
(In Topic #106152)
Member 125 - 2005
battery relocation
i want to relocate my battery into the boot, but i want to keep it easy to reverse back to standard. would i be able to do it this way and what size cable is recomended ?
this is what i thought…… battery in the boot, neg wire connected to the rear bumper bolt into chassis . run a positive wire from the boot to the existing positive terminal in the engine bay and connect using some sort of junction box , and then connect the neg wire in the engine bay onto the front chassis leg.
any views on this ? and recomendations of parts? cable size ect cheers jim.
Member 125 - 2005
I connected all the lives to the stater motor live, don't know weather i was right to do all this though as i'm having an electrical nightmare with clocks and stuff now. But then again I did all of this because of a 18t conversion so your biting off alot less than me.
Member 125 - 2005
Member 125 - 2005
rpatten have a word with ben , i'm sure he will put you right.
ben have you heard anything of my old car lately ?
mk1jim said
that's what i will go with,
doing lots of miles had a call before xmas to say he was having a few lack of gears issues think the cables had moved
apart from that i think its getting abused like it should :mrgreen:
Member 125 - 2005
rpatten said
I ran a negative and a positive from the boot to the bay with new wire and terminals. cost me ?50 quid so if you can get the wire cheaper then you've done well.
did it when i fitted the TT lump to mk1jims old car but i didnt go straightto the battery
i left the original battery live lead under the bay and bolted the new cable into it then isolated it also ran a extra earth from back to front
