Battery or more issues after 3 months rest.
(In Topic #146386)
Still have a few issues though. After running for about 10 mins at fast idle, the battery still had no charge when I tried to start it again. Is there a chance it could be a dodgy alternator or just a capput battery. Or did I not let it run long enough? I'm not particularly experienced in things like this. Is there an easy test to check the alternator?
Also I'm having some issues with the dash. The only lights coming on are the handbrake and carb lights, and the full beam LED on the dash. No other lights are working along with the rev counter and fuel gauge.
Any help would be appreciated as I would love to get her running for a trip down to Players
Wait until you have fitted a new battery before doing any more electrical diagnostics.
We were playing again earlier and it got to the stage where the engine cutout as soon as we removed the jump leads. Does that fit with a dud battery scenario?
Rich
I know the battery is flat, just not not sure why its not keeping any charge.
I'm gonna get a new one tomorrow I think, the current one is at least 3 years old and it would probably help having a decent battery for winter.
Wikipedia;
Lead-acid batteries should never be discharged to below 20% of their full capacity, because internal resistance will cause heat and damage when they are recharged
Basically if you discharge the battery too much you can (not always) kill it and it will never hold a charge again.blue-BUF said
I'm not sure what that will achieve?
Didn't start mine for about 2 1/2 months and only got a few turns from the starter before it died, put on quick charger for a bit and would turn over but not start (bit impatient of me I know) Got some booster cables and started up straight away so that ruled out any other probs. Then put battery on slow charge from morning to evening and after that started up with no help and has done since.
I know on mine it's only running the clock but it obviously does draw a current and drain the battery + not sure if you have an alarm system which again draws more.
Anyway hope you get it sorted.
Dan
Early-1800 said
Looks like you've killed it by letting it go completely flat;
Wikipedia;
That's a good reason never to believe anything on Wikipedia! Its a load of balaerics.
A deeply discharged battery will, if left discharged, start sulphating, which is a more/less permanent chemical process on the cells reducing the active cell area available, and therefore battery capacity.
A deeply discharged battery can be recharged if its not left, so long as the voltage/current regime is appropriate to the battery and its not allowed to gas off, which will reduce electrolyte volume, or heat up too much, which could potentially result in a runaway reaction and explosion of the battery.
Decent battery chargers will be 3 (or more) stages (bulk, absorption, float) and will have temperature sensor to allow higher charge current with no danger (ie too hot and it will reduce charge current).
I remember years ago a mate with a totally flat battery trying to bump start his Polo down a 2 mile hill and it still wouldn't start.
Best to fit a higher capacity battery designed for a Diesel Golf and keep it charged by using the car regulary or if laid up get one of those CTEK chargers. Hope I'm not tempting fate but the GTI battery is about 6 years old and seems to be going strong….
1988 1.8 carb Golf Clipper
Ive still got an issue with the dash if anyone has any ideas. The rev counter, fuel gauge, temp gauge and battery and indicator lights have all packed up in one go. They won't all have broke at the same time surely?
Just a quick question John, if I lost the live ignition feed, would I still be able to start the engine?
So far I've found that the earth for the instrument panel is good and that there is continuity between the connector from the inst panel and the ign live feed from the cluster. Now I'm stuck as if I follow the black wire back it gets all complicated because of the immobiliser. Also I don't have a battery in at the moment so I can't do any voltage tests.
Do you know if the immobiliser could be causing these problems?
I still haven't solved the dash problem but I'm going to focus on one bit at a time, starting with the alternator.
Any advice would be much appreciated
Rich
I have had a battery problem also which i posted about 5 days ago, Halfords told me the battery is ok, i charged it today and fitted it, First thing i noticed was i had no dash lights (battery-oil) only thing that worked is the high beam light and clock. my car starts ok and runs, i have checked the alternator and everything is fine.
Why no Oil and Battery lights? the were working when the battery wasn't fully charged!!
