battery grounding wire
(In Topic #122072)
I seem to have a grounding wire from my battery that isnt bolted to anything, can anyone help me identify where it is supposed to be bolted to?
Dan
Have you got a ground connection to your gearbox? what about the coil?
let us know! ;-)
ground
Thanks for the reply! Its a 83 gti with a diesel starter motor. The wire is thee thick brown wire coming off the negative post of the battery. I have the first bolting position just hanging by the passenger side engine mount. I cant see the normal position for it to be bolted too. The car has a few symptoms such as irregular and slow turning over, sometimes a pause when i turn the key and come times the starter carries on on spinning once i have released the key. I have also tried to push the wire to the engine mount when turning over and it sparked. All of which doesnt seem right at all!!!! I have replaced the starter and ignition switch with vw parts. Will try putting a pic on but i have got to workout how to get them off my new iphone lol!
Thanks for the help
Dan
Hopefully it hasn't done any damage . . . . .
grounding
Here is the pic of the wire, i tried attaching it to a gear box bolt but no difference. will try to the gear box mount tomorrow. Thanks for you input!
TRY THIS!
ground wire pic1.aspx | shepfern | Flickr
end of wire should be connected to engine, middle of wire to suitable bolt on body somewhere :-)
Thanks guys
As said above your slow or iregular starting will be due to a earthing problem so it all ties in. You should have a +ve a ignition switched +ve thats live when you turn the key.
Just a thanks for all the help! I attached the grounding wire below/behind the air box to the chassis leg and the gear box mount! started everytime and consistantly so thanks for your help!
Dan
shepp said
Hi again
Dan
Looks like I'm a bit late to say it goes to the chasis leg, but anyway yes that is where it goes
