Battery Draining
(In Topic #105753)
Battery Draining
I was looking for some help…the battery on my 1992 Cabby keeps draining flat and I have no ideas where to start looking for the solution!
The car has an alarm, immobiliser, radio and thought it could be these. I have made sure no switches have been left on. The battery is fine.
Please could you give me some pointers as to where I should look myself before I have to take it to a garage (trying to save money after xmas!)
Thanks in advance
then you could really do with rigging it up so you can measure current draw, and then turn the alarm on, etc.
1989 VW GOLF GTI CABRIO
1997 VW POLO 1.0L
2003 VW PASSAT TDI 130 SPORT
1997 VW POLO 1.0L
staffords said
Had same trouble with mine a few weeks back so i got a new battery which soon drained. It turned out to be the regulator on the alternator, the auto electrician only charged me ?20 and he fitted it too 8)
Hence, measure the voltages - on 'charge' a good alternator will give approx 14.3 volts. A lousy one (worn reg) less.
But to be sure and for the sake of not giving lazy answers.
connect just the alt to a fully charged battery and see if it drains or use a component checker on the regulator, or scope on the output from the alt. (if you have one)
*edit* to add something *usually one or more of the diodes in the regulator goes short(rarely open,unless its got a hole in it) so your can actually test for that with a normal resistance check if you know what your doing.
~Madferret
Mk1 1457cc 5door GX '83
