BAD EARTH ? - WHERE DO I START
(In Topic #140166)
WHERE DO I LOOK / START ?
I ALSO BELIEVE THAT THIS IS WHAT HAS CAUSED ANOTHER LONG-STANDING INTERMITTENT PROBLEM THAT I HAD WITH OCCASIONALLY LOSING POWER WHEN DRIVING, BUT NOTHING COULD EVER BE FOUND. THIS ALL NOW MAKES SENSE, SO FINDING THIS MAY BE A MAJOR RESULT FOR ME.
I AM NOT A 'MECHANIC' AND THIS IS A NEW SYMPTOM FOR ME SO I'D APPRECIATE ANY HELP ON HOW MANY AND WHERE THE EARTH'S ARE WITHIN THE ENGINE SO I CAN FIND AND CHECK THEM OUT - OR ANY ADVICE WOULD BE GREATLY APPRECIATED.
THANKS
Black Cabby
Black Cabby
If it lights or the meter registers voltage with no key you have issue.
Remove each fuse in turn and see which one turns the light out, that will hopefully identify the circuit thats drawing current.
Do this again with the key on first position as some are switched live ie some are permanent live and some only active with ign live.
Black Cabby
