Bad earth - one dipped beam goes out when main beam engaged
(In Topic #80448)
Guest user
Just took the mk1 in for an MOT, failed one things
1) when changing from dipped beam to main beam, the offside dipped beam bulb goes out (the near side one stays on) - the tester said a faulty earth?
basically. how do I go about testing if my cars has a faulty earth, where should i check?
any help would be great.
thanks
will
sounds like a fuse or wiring fault to me, best way to check is with a multimeter and haynes manual
I have an old stock new fusebox in original box 8)
Guest user
sorted!
I attacked the problem last night and after wiggling earths, replacing fuses and bulbs the problem seemed to sort itself.
I love my mk1.
