Alternator failure?
(In Topic #142172)
Alternator failure?
Anyway, we drove it back from Edinburgh fine but ten days later it has stopped charging, I think, although the alternator light goes off on start up? What causes a sudden charging failure, is there a fuse or relay that may have failed.
Thanks in advance (ive heard good things about this club) Oh yes and a wiring diagram link would be nice
Darren
Alternator failure is usually down to a couple of things really Poor earth, worn out brush pack or regulator.
Plus the blue exciter wire becoming broken. It's on the back of alternator.
I would clean up all the cable connection points inc those to the chassis to start with and with all electrically things off, such as lights, heated rear screen, radio etc, test what voltage you are getting between the battery terminals usually around 13-14V.
It seems straight forward enough to replace the brush pack. Remove alternator, undo the 2 screws either side of the regulator pack lift out carefully, using some contact cleaner clean all contact points the brushes run on too.
Plus the conatcts that any electrical connectors go to aswell.
Just make sure your battery isn't duff and if it's a non sealed type the electolite level is okay.
Regards
Darren
Darren
