abf ignition wirring what do i need
(In Topic #148519)
I'm a bit confused on what i should do with the coil, spark side of things.i have put an abf in a 8v gti its all in a turning over just need to sort out a spark can any one tell me what i should be using and what i need its still the,original gti fuse box and its running on carbs so no need for ecu thanks PS i am wirring idiot :dontknow: :dontknow: :dontknow:
also if it was a points ign car you will have to add a new ign live feed to power the coil, the pooints ign system uses a resistance wire to lower the voltage which is no good for electronic ignition. oh and you'll need a tci unit too ifg it was points, its above the ecu on a mk2 and in the scuttle in a mk1
