99MPG ! ! ! ! ! how do i calibrate this ?
(In Topic #81193)
even all my dash lights - which has taken a little time
but the mfa tells me im doing 99 MPG, and after 2 months of owning the car, im starting to think this isnt correct
is there anyway to correct this, or calibrate the mfa?
where does the mfa get the fuel consumption from ?
thanks
Jon
If you do a search on the site you will find how to replace the vacuum unit at the rear of the panel , but you need to find one first 8O
Cheers………..
PS i have no idea how it does its calculations on MPG …..
when I get the time will pull out dash clocks and reconnect.
ive recently replaced the dashboard, so i refitted the one vacuum pipe when i did this
thanks
jon
