92 GTI only the high speed for wiper works
(In Topic #141365)
Am not familiar with the way the rear wiper works either. When i push the lever forward I get washer fluid to the back window. Not sure of the correct way to operate the rear wiper. I bought the car about 8 months ago and have no operators manual for it.
Ive replaced both the highbeam switch and the wiper switch. Am thinking maybe a possible relay problem?
Replaced the highbeam switch due to not having any headlights unless i held the highbeam switch in. Problem was the on/off switch its self.
Am mechanically skilled but electrical is my weak point. Any suggestions would be very helpful.
rear wiper should work same way the washers do. the fact the washers work means the stalk and wiring from it to fusebox is ok, so look at the rear motor, wiring and the control relay #20.
for relay positions see the fusebox sticky
