83 Tintop brake lights
(In Topic #152178)
WWW.DUBSHIRE.COM
as for the wiring both rear lights run from the same wire to the fusebox, the fac 1 side works means this wire is fine. all it is the wire comes up from the rear to one of the lights, then the other side is piggybacked onto it. check the red/black wire to both clusters, check the earths and also check the light clusters themselves they can get corroded
