83 Mk1 GTI - Alternator Replacement
(In Topic #163960)
I'm after a bit of help with my Alternator, basically its gone on the blink and need to replace it. There sems to be many variations of Alternators available. I have taken the part number from mine. Its a Bosch 0-120-489-008 K1-14V 55Amp. Does anyone have details of the replacement part and where to find one, alternatively is there a higher Amp version that would fit in terms of mechanical fitting and electrical connections.
Cheers, any help appareicated.
(1) | 036903017AX |
| alternator
45A BOSCH /
(1) | ——— |
| no longer available
45A BOSCH /
(1) | 068903017FX |
| alternator
65A BOSCH /
(1) | 036903023NX |
| alternator
45A MOTOROLA /
(1) | 036903023PX |
| alternator
65A MOTOROLA /
(1) | 060903017AX |
| alternator
45A BOSCH /
(1) | 060903017 X |
| alternator
65A BOSCH /
(1) | 068903017CX |
| alternator
65A BOSCH /
(1) | 049903017CX |
| alternator
65A BOSCH /
(1) | 060903017AX |
| alternator
45A BOSCH /
(1) | 049903023TX |
| alternator
65A MOTOROLA /
(1) | 068903017PX |
| alternator
90A /
(1) | 035903017AX |
| alternator
90A BOSCH /
copied and paste from VAG CAT
No 55amp ones though!
Do some searches on the part numbers, I think 65amp is standard for a GTI. Could be wrong though!
You might find an alternative.
main thing to worry about is your alternator cable, if your car is old enough it may hve the 3 pin spade connector rather than ring terminals, if so and you end up with a later alternator then use a mk2 golf alternator cable. mk3 golf one works too but need to crimp a ring terminal n the blue wire alternator wire and splice a spade on the car end. you'll see what i mean anyway
