16v cold start valve..
(In Topic #118866)
It seems as though i dont have a pin 15a on my starter solenoid :dontknow:
which means i have no where to plug the black cold start wire into
is there anywhere else i can plug it in?
thanks
Thought i read somewhere that if a throttle switch connection is not used then you can just hook the csv to -50 starter pin..? or am i talking rubbish?
std fitment on the 16v, its controlled by the metal vac switch on the back of the airbox. This gets 12v from the idle switch with the throttle opens and the vac switch passes current when it sees a hard throttle condition.
if you don't have this then yeah you could do that
Il just chuck my spare starter on…
thanks buddy
