1.1 WIRING LOOM FOR 1.6CARB??
(In Topic #112747)
I'm not an expert because I don't really have that much experience with small block electics! So just suggesting vague general things to check.
the rev counter signal wire should be there, as it is still needed for the oil pressure warning circuit to work, unless the earlier MK1s only had a low pressure warnign switch and not a high pressure warning?
Appreciate it
on the MK1 petrol models there is only 1 rev counter wire from the coil, both the rev counter and oil warning circuit are then spliced into this wire. However the wire might not be there on the 1.1 loom if as you say it only has 1 oil pressure switch, but I dont know for sure
mk2 would be kinda close but the trouble is the fusebox on the mk1 is on the passenger side, and driver side on a MK2.
all depends how good you are with the wiring side of things really. A MK2 carb engine managment loom should work ok, combined with the MK1 1.1 sensor loom. the managment bit doesnt run inside the car, just from hall sensor -> coil -> tci and a wire to the battery -ve
