"creamy hood oil" question
(In Topic #121169)
that all went fine and when i got a chance i checked the oil level and bled it as shown below. all ok.
my question is this….
my oil looks perfect in colour and level when the hood hasnt been moved for say ten mins, i lower or raise it and look in the pump reservoir and the oil is creamy looking and there is more of it. let it settle and it goes back to normal.
my guess is that its getting air into it somewhere, but the hood goes up and down ok, its a little slower going up than when we got it too. can anyone shed any light or had it happen to them?
put it up last night its sooooooo sooooooo much slower than when we got it last year!
Failing that ,using your manual for guidance, disconnect the hydraulic unit including all pipes a inspect it including any seals which have most likely perished.
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
any vw dealer would be a good start.
ask on here if someone can get you the part numbers from etka then you`ll have more chance locating some.
good luck and let us know how you get
