[b]oil light and buzzer issue[/b]
(In Topic #143368)
i thought it was a oil type issue drained , refilled with 20w50, replaced the sensor on the oil filter.
still there, when i put my hand at back of dash and fiddle it quite , or hit hard on the dash is gone for a while then back.
there is no stange engine noise , does not use oil , runs 100% , throught the engine oil filler when idling i can hear the oil splashing around as it should.
will replace the top sensor this afternoon, this flippen buzzer is driving me crazy.
what else can i do to stop the buzzer pls
regards
deon
regards
Deon du toit
RSA
Deon du toit
RSA
I finally found it to be the actual speedo head, the grease in there had dried out, I added some white grease and it's been fine ever since. The part I'm referring to is the white plastic bit in the image below:
It's fairly straightforward to remove and dismantle the clocks to get to this. I can't fully understand the reason why it's caused the buzzing/squealing but it fixed it for me.
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
regards
Deon du toit
RSA
Deon du toit
RSA
This was a last ditch attempt for me to solve the problem - I changed the circuit board which made no change, changed the voltage regulator, oil pressure sensor, coolant sensor, oil and filter, checked all the earths etc etc etc and all made no change.
I then bought a full set of clocks and changed over just the speedo head, this solved the buzzing but caused a misread on the speedo reading compared to my sat nav. I then knew the problem was in my original speedo head, it can't be dismantled but I noticed the dry grease so cleaned it and then regreased.
regards
regards
Deon du toit
RSA
Deon du toit
RSA
