Water pump for 1.5D
(In Topic #154665)
Early big block similarities
Hi there chaps,
The water pump on my '77 1.5D motor has started to leak since I've been using the car as my daily driver, so I need to source a new one, which seems a difficult business considering the limited number of 1.5D models left, very few stockists carry any any engine bits for the early oil burner. My normally-excellent local motor factors tell me it's a discontinued part, and although Heritage list the pump they don't have any available.
Am I correct in assuming that a water pump for any early big block petrol lump will work on my engine too, as from my limited understanding I believe the early diesel engine was more-or-less a converted petrol motor? The engine code is CK.
Thanks in advance for any advice ~ Craig
'77 Golf 1.5D
Twitter Manager
I work in a motor factor. .. I'll have a search for you tomorrow
Thanks fella, that'd be a big help
'77 Golf 1.5D
Twitter Manager
Well from what I have puzzled out the 1.5 petrol uses the same pump.
http://www.ebay.co.uk/itm/WATER-PUMP-FIT-FOR-VOLKSWAGEN-GOLF-CABRIOLET-1-5-1981-1983-FWP1106-/230788294296?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35bc0de698
with back housing..
http://www.veedubmachine.co.uk/index.php?main_page=product_info&cPath=422_9_156_172&products_id=1922
will do some more investigating tomorrow..
with back housing..
Thanks a lot, that's great, especially as veedubmachine is only half a mile from where I live
~ Craig
~ Craig
'77 Golf 1.5D
Hi,
isn't it the same as the 1600 diesel? It certainly looks the same and the 1600 was fitted to Mk2 Golfs too. I'll just pop out and take a look…
Robin
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
Hi again,
I've had a look and they are almost certainly identical from the outside - I can't see any differences between my '79 1500D and an '88 1600D engine I'm rebuilding. The housing which goes on to the block is slightly wider on the 1500 but has the same fittings.
Hope this helps.
Robin
Hope this helps.
Robin
Thanks chaps, and no Bert, your memory doesn't fail you, the pulley on my original 1.5D pump is definitely different to the one needed to fit on my new replacement pump… On the lookout for one now
~ Craig
~ Craig
'77 Golf 1.5D
