help please
(In Topic #145086)
help please
you can just see it in this pic
are you getting air in the fuel lines only when hot?
when it's at a stand still does the fuel dissappear back to the tank?
you need to stop the air, few things to check
check the seal from filter to housing,
replace old copper washers on each fitting,
make sure pipes are good and not old and perished
check all jubelee fitting are tight and the correct size for size of pipe, Larger clips when tighten to much turn oval and dont seal correctly
check the pipe at the tank end
wiggle the accelorator lever on the pump if air gets in the pipe the shaft seal has gone
just a few things to keep you busy
ps moved to the deisel sections
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&p=742664&highlight=#742664
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
