Pirelli P Slot Centre Caps
(In Topic #184773)
Just a quick question, I think the answer is probably yes but just want to check ! Will centre caps from Mk2 version P slots fit Mk1 P slots and vice versa or are they different ?
Hope someone can help with this ?
Yes they'll fit no problem
Center Cap #VWC39 (Silver W/ Black Rim)
Numbers On Back Side: 191.601.149A
24045907
Physical Size: Approx. 6 1/2 Inches Wide
Center Cap #VWC12 (Silver W/ Black Rim)
Numbers On Back Side: 323 601 149
191 601 149 G
1-4180-1 WZ 1
Physical Size: Approx. 7 Inches Wide
Center Cap #VWC40 (All Silver)
Physical Size: Approx. 6 3/8 Inches Wide
Nothings ever simple as it seems !!!
24045907
191 601 149 G
1-4180-1 WZ 1
cheers hairyarse I just found this ! the ones I have are the 191.601.149A
http://www.hubcaps.org/options/vwc39options.html
If you look on partbase too, for 1985 MK2 for example it lists the 171 part number (MK1) and 191 (MK2) part numbers on the same wheel
partsbase.org
Hope that helps too
partsbase.org
Hope that helps too
carefull, its not as straightforward! mk1 caps are very loose in a mk2 wheel ! i lost one driving down the a47 some time ago. The cap in question was with the raised pirelli logo (i spent two nights walking down the road looking for it, but no luck im afraid
and vice versa, the mk2 blank cap is extremely tight in a mk1 wheel, so much so that getting it in, or back off again is very difficult.
Im away at work at the moment so cant take any measurements or part numbers im afraid
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
