Job lot of audi and vw parts.
(In Topic #222002)
audi80/10/gt/golf 1 parts.
These are NOS still in their packaging mostly.
Edited to remove non Golf parts and added prices, Cheap they are. Photos of the parts.
026-198-049B PS overhaul kit X3.£5 each
026-198-025A rocker gasket. Caddy 1983-1992 | Corrado 1989-1995 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Golf Mk2 1984-1991 | Type 25 1980-1991 1.5-1.8 Petrol engines 1.6 Diesel engines £3
027-121-065C X5 water pipe. Golf Mk2 1984-1992 1.6 to 1.8 carburettor engines. £10 each
027-103-419 valve guides (TRW) X5 sets.(for 16v). £5 each
030-198-012D head gasket kit.
034-198-025C rocker cover gasket X2.£5 each
034-198-025 cork rocker gasket kit. £5
035-103-383J head gasket.
035-103-609 sump gasket.
035-133-837AB air filterbox top cover ur.£15
035-198-025C OEM vw/Audi rubber rocker gasket.£7
048-198-012 head gasket kit fits AAD/ABK.
050-103-383A head gasket.
058-198-012 head gasket kit.
111-905-865C ignition switch.£7
171-402-303C front bump stops sus golf1. X2 £10 Pair.
171-407-153D wishbone 924 1980-1988 | 944 1982-1985 | Golf Mk1 1975-1983 | Scirocco 1974-1981 £20
171-419-804 tie rod complete with tr end (golf 1). Caddy 1983-1992 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Scirocco 1974-1992 £15
171-798-211 gear shift bush repair kit (x9) Caddy 1983-1992 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Scirocco 1974-1989 £5 each
171-798-105 clutch cable fitting kit X2. £3 each
171-498-625D bearing kit X2. Mk1 Golf Mk1 Golf Cabriolet Mk1 Jetta Mk1 Scirocco Mk2 Scirocco Caddy £12 each
171-711-574A selector rod X5. For all 1500-1800 4 speed models £3 each
171-711-574B selector rod X5. Mk1 5 speed, 1500-1800cc models, 5 speed £3 each
171-711-593D selector rod X5.diagonal shift rod 4 speed £3 each
171-819-809F heater valve X2 £5 each
171-321-308 Inner rubber guide (fits clutch cable at gearbox). £3
171-419-812 tie rod end X2.£10 each
171-711-593F selector rod X5. £3 each
171-419-832K.rack gaitors X2. £10 each
171-407-331F inner cv joint.X2.£20 each
171-611-019E. brake master cylinder.£30 (german)
171-419-883 steering rack mountings X2. £3 each
171-419-884 steering rack mountings X3 £3 each
171-611-701GL front flexi X2. £7 each
171-407-643A hub nut self locking X6. £1. each
171-798-211 gear shift bush repair kit (x9) Caddy 1983-1992 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Scirocco 1974-1989 £4 each
171-498-625D bearing kit X2. Mk1 Golf Mk1 Golf Cabriolet Mk1 Jetta Mk1 Scirocco Mk2 Scirocco Caddy £15 each
171-609-721 brake cable X3. Handbrake cable, 2 required - To suit: - Mk1 Golf 75-75 to chassis >> 175 3025 867 - Mk1 Scirocco 74-75 to chassis >> 535 2001 030 £10 each
171-711-574B selector rod X5. Mk1 5 speed, 1500-1800cc models, 5 speed £5 ea
179-609-721 brake cable X2. Caddy 1983-1992 £7
192-721-555 accelerator cable X2 (NLA).golf2-carb,8/83 to 7/92, jetta 2 carb 8/83 rhd. £10 each
191-711-115 rubber gearshift gaitors X2. £5 each
1ho-711-115A g.shift gaitor leatherette. £10
Last edit: by Overboost
