engines and parts , gearboxes , callipers , suspension etc
(In Topic #221088)
Following on from my clear out I have gti engine in bits abf in bits , loads of random parts as well flywheels , gearboxes , mounts , cables , pipes , full carb engine , carb engine bits , gear linkage parts , brakes , suspension parts , arb's boxes of the stuff
Will list pics but as you can imagine this will take some sorting so if you need a part worth a ask
Do you have an original gti 6 bolt exhaust manifold?
Sent from my SM-A520F using Tapatalk
I don't sorry
Hi hibbs, do you have gti fuel lines from metering head to injectors?
What year is your car
1991 cabriolet
1991 cabriolet
Hi
Do you have any timing belt covers for 1.8 8v carb model?
Thanks!
Thanks!
1991 cabriolet
Yes just there's different types of threads on them course early cars or fine later £50
Do you have the plastic camshaft cover which sits under the rocker cover? I have a 1.8 GTI 1983
Dan
Dan
Dan
Had a check and I don't think I do
Regional Host NE
hi mate i have one if you
still after one
cheers paul
still after one
cheers paul
Have you got a decent looking crank pulley?
Cheers, Adam.
Cheers, Adam.
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
Regional Host NE
sure i have a couple mate
Great stuff, how much are you after for one?
It off a gti? In all reality I'm sure it doesn't make much of a difference but will check the part no if you've got one
'83 MK1 Golf GTI
Regional Host NE
hi it was of a running engine no movement
on the tvd damper 026105243c
cheers paul
cheers paul
Re:
cheers paul
How much would you like for it? PM me if you prefer
Cheers,
Adam.
Sent from my Pixel 2 using Tapatalk
'83 MK1 Golf GTI
After passenger door seal 1991 Cabby please
Regional Host NE
Re:
How much you after posted Paul?nicci21paul said
Cheers,
Adam
'83 MK1 Golf GTI
Regional Host NE
job done hopefully
