1.6D engine breaking for spares - Tadcaster, N. Yorks
(In Topic #207071)
Hi guys, I've dismantled the old 1.6D block that used to be in my van so have a few bits to offer. The engine code is 'JP' and I believe originated from a Mk1 Caddy but afaik parts should be interchangeable with other N/A 1.6D vag cars. Please make your own checks (part numbers below) to be 100% certain.
Cylinder head, comes with cam/followers etc, small cracks between valves on 3 chambers but are fine and within tolerances. The studs for the water outlet on the front of the head have sheared but there's plenty of thread exposed to assist removal. Part number 068103373D
£40 collected, can post if required.
Fuel Pump (picture and part number to follow)
Injectors x 4 - part number 068130201N
£60 posted
Hard injector lines
£25 posted
Other parts available, pulleys, pistons, conrods etc - block is scrap as case had been drilled for fitment into a T3.
Located near Tadcaster, North Yorkshire.
Gav - 0779617298
£60 posted
Hard injector lines
£25 posted
Gav - 0779617298
