Breaking mk1 golf tin top and cab parts!!
(In Topic #201298)
Breaking mk1 golf tin/cab
Breaking Mk1 golf tin top/cab loads of original parts!! Have stainless steel fuel filler neck…Give me a bell on 07955 419714 or email me shanemc68@outlook.com as I'm not always on this site…Nice one 😀
Last edit: by ebony
Have you got a drivers side door capping for a cabriolet please?
Hi got a couple of cab doors so will check condition
Brilliant, thanks
Do you have a rust free cab tailgate? And the gas struts for the roof?
I just chop the chips🍳🍳🍳
Do you have a rust free tin top tailgate?
Don't have rust free tail gate for cab or tin…and no hydronic struts….already gone!
Cheers chief thanks anyway.
You have a Cabby rear view mirror?
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
Do you have a pair of seat frame cover/caps please the black plastic ones?
Do you have the plastic small bumpers with the chrome trim on them, the GL spec ones?
Currently Mk1less!
Currently Mk1less!
Do you have gti drive shafts off a cabby and the cover that bolts to the engine shield from the exhaust
Stainless filler neck for cabby???
Ebony, any updates?
Hi any hydraulic power roofs in torn condition? Requiring frame and strapping still intact
On the drive
Myvalver 89 GTi Grey mk2 16v
How much for the complete front seat belt setup including postage for a tintop..Not sure if cabs are the same? i.e all bolts,brackets,clips. I have a racing harness setup in mine and want to revert back to standard.
Do you have a complete set of rear seat belts for a tintop? I would need all bolts, spacers, washers etc as mine has none.
Thanks.
Thanks.
Any chance you have a cabrolet roof? if so what colour and condition? cheers
Do you have the oil crankcase breather hose t-piece from top of engine. Part number 026103247?
Also I'm after……
VDO 52mm volt gauge
Side mirror controller bellows
Plastic triangle trims from base of convertible hood.
VDO duel pole Sender unit 80psi/5bar
Rob
Also I'm after……
VDO 52mm volt gauge
Rob
Mark carter funkster has most of your list. For hose heres link for new..http://www.volkswagen-classic-parts.de/ventilgehause-motorentluftung.html .
On the drive
