Strut top replacement....
(In Topic #186159)
the car is very crashy at the front end with a knocking noise going over bumps while turning. I just thought it was the rubbish coil overs. Anyway, going to replace the top mounts. is the kit below suitable to use with coil overs? Does it matter if you have a standard setup or coilovers, to which top mounts you buy?
appreciate any help, thanks
Someone might tell you that they are still fine as I'm no mechanic but they look interesting :-)
You are better with Febi top mounts IMO and u can get them and all the bump stops and covers from funk-star on his classic-vw site on the homepage.
also get 4 new nuts, spring washers and washers from his site when your at it :-)
http://www.classic-vw.co.uk/mk1-golf-suspension-dust-shield-4183-p.asp
http://www.classic-vw.co.uk/mk1-golf-suspension-bump-stop-4184-p.asp
http://www.classic-vw.co.uk/mk1-golf-top-mount-spacer-4186-p.asp
http://www.classic-vw.co.uk/mk1-golf-top-mount-spring-washer-4188-p.asp
2 of each except 4 spring washers and message him for 4 normal washers and 4 nuts.
He even told me at the show last Sunday
Your suspension has been on and off more than most
Massbad69 said
http://www.classic-vw.co.uk/mk1-golf-suspension-top-mount-febi-3882-p.asp
Great shout Chris - I'm missing some of those parts too.
funk-star said
Did I mention I'm changing to a premium rate number
Haha - need to email then.
Couldn't find any of the items on location 1 or 19 on your site Mark so my order was below the min £9.99
Looking for 2 of item 1 and 2 of 19. And 4 of each of items on location 13, 14 and 15. I'll email you too.
Regards Iain
Regards Iain
Iain
I think its today the Mark is away on his hols, I thin k hes back to work on the 9th June.
Remind me then and I will help u sort the parts out.
Chris
Just needed to set a early deadline for orders. :-)
