Silent Coat Sound Proofing - Help
(In Topic #213070)
Has anyone used the Silent Coat products as that's what I'm using, and has tips as how best to install this product please…?
I'm using mat volume pads and then isolator sheets over the top through out the entire interior area of my 1988 cabby.
Thank you as always.
Any hollow area is going to amplify any and all sounds
That soundproofing doesn't look as if it is very thick at all.
With the condition of my hearing loss, (Turbine engines droning in my ears for 4 years). I don't hear too many rattles, but then again I drive with the Top Down, Atomic Batteries to Power, and at sub-light speed.
Don't discount good carpet padding to reduce additional noise, as it is a good muffler as well.
Over here they all prefer Dynamat, but that stuff is a wee bit pricey for me. 100 bucks gets you Self sticky Aluminum Foil backed Butyl Self-Sticky rubber for roofing at the hardware store, More than enough to do about 3-4 Mk1's and it isn't that smelly once it airs out. In Vert's you hardly notice it at all.
my 2P.
I'm about half way through the entire floor pan with the silent mat. Silent Coat will apply tomorrow.
Have plenty of pics to share on a new specific thread once done so I can share my experience with the club / forum.
Sneak peek….
I've gone with Silent Coat 4mm, Dodo Matt followed by a generic cheap 5mm self adhesive foam. The Dodo matt helps to stop higher frequency noise and the foam is to stop things from rattling against the harder materials below.
Looks like you're cracking on with it.
Where did you get the self adhesive foam for you're final later please?
MOT later today.
Here's the foam. I used it on the inside of the roof panel and all over everything
http://www.ebay.co.uk/itm/1mx5M-Roll-Car-Sound-Proofing-Deadening-Van-Closed-Cell-Insulation-Foam-UK/122545178632?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Ian
borednow said
Not driven it yet!
MOT later today.
Ian
So…. how did the MOT go…???
Thanks for the link, it's what I had, ordered exactly the same stuff funnily enough.
Birchy
