oil pump priming
(In Topic #194965)
The oil pump is topran and not that old.I tried to draw oil up from what was drained but no joy,it will pump merrily if primed.
Is this just the nature of the beast,are gen vw the same.
i read Jonny's trick re priming and sealing end with Vaseline.
Hairyarse said
Was about to comment here too but seen the replies on FB.
Not everyone is on facebook……go on - share the knowledge!!….
I had said that it's not the norm to have to prime the oil pump at an oil change.
I think that Mann were the maker of the VW oil filters? And, that non-genuine filters can have issues with the oil pressure relief valve, but wouldn't have thought it would cause an issue on one from new.
Does that sound about right Yomp ?
as i said on facebook if you pop the dizzy out and make up something to drive the oil pump slot drive from a battery drill that can help you prime it up without having to crank it over for ages
