Is my sportline sat right?
(In Topic #218572)
Hi all. So ever since I have had my sportline about 6 weeks the back looks to sit a bit low and the front a bit high. Im thinking about changing the shocks and springs for the bilsten/eibach package but dont want it to be too low either.
So my questions are.
1. Is my sportline sat correct or have the rear springs sagged as dropping it further on the rear I think will look odd.
2. The bilsten/eibach kit says it drops the car 30-40mm but given I have a GTI is mine already 15mm lowever anyway so I would in effect get a further 15-25mm worth of drop?
I dont want to throw money away if its not going to make a differance or in fact worse if too low on rear as there is lots I want to do to the car.
Is your garage floor not flat, or is that my eyes?
How dare you I built that garage myself... lol.... no mate its flat. Well actually it has a slight run towards the doors but im talking 20mm over 6meter run just incase any water got in.
Ok so not many takers… some more info the feont of my cabby sits 30mm higher than the rear when measured from centre of wheel to arch. Does anyone know what the correct measurements should be as my worry is I need new shocks and springs as mine feel shot… was going to go for the bilsten/eibach comb however it drops the front and rear 30mm which is good for the front bit would say the rear is already low enough. So trying to understand if rear has sagged before buying and fitting suspension to just find out rear is too low.
Would go coilover route but cant seem to find any consistantly good reviews for the £400 mark.
It looks fine to me, as that is about the stock height.
There is a rubber bush on top of the rear strut which go flat over time, have a look at them, you will need to drop the strut down to see how they look.
Part 9 and 8 are the bushes but part 9 takes all the weight.
https://www.vwheritage.com/golf-mk1/mk1-golf-suspension/rear-suspension
Old bush
http://i47.photobucket.com/albums/f197/mark1gls/CIMG3842_zps47e88770.jpg
New bush
http://i47.photobucket.com/albums/f197/mark1gls/CIMG3843_zpsee26d06b.jpg
Old bush
New bush
You forgot the part about needing a SAWZall to remove the lower bolt if he hasn't mummified the bolts to prevent them from Seizing in the lower bushing mount bushing.
How I do it.
How to replace your Rear Struts | Volkswagen Owners Club Forum
How I do it.
