Distributer
(In Topic #198265)
I just removed my dizzy with the number 037 905 205f is this right for a dx engine? K jet
can you get a hall sender for them still
any help be good
any help be good
nope sorry, thats a digifant gti one totally wrong for a kjet
That's what I thought, which one should I have not a vacuum advance
you'll need one with the vacuum advance module on the side, they also have a weighted advance system inside.
the trouble with the digifant one is it has no advance mech at all, its purely used as a cam position reverence by the ecu which then does all the ignition advance calculations from an internal fuel/ignition map.
if you're desperate it will run the car, but it'll be proper flat!
Oh cool think I am getting a second hand one now. Off an 83 cab hopefully that should work thanks
