Carburetor held on with cable tie
(In Topic #222139)
Once you've found what's missing, it should be a reasonably easy fix.
Take a look athe pictures attached, the new plate seems to have some of the correct fixings but the carb doesnt seem to fit on that plate, and appartently that plate is correct for the car.
I'm hopefull one of our experts will come along with an answer
Take a look athe pictures attached, the new plate seems to have some of the correct fixings but the carb doesn't seem to fit on that plate, and apparently that plate is correct for the car.
I'm hopeful one of our experts will come along with an answer
paul_c said
I believe manual and auto have a different inlet manifold with a different fitting for the carb. Did you look at an auto on the forum pic you compared yours to?
Oh good shoot mate
Heres the link, really need to get these parts ordered, i'm surprised she runs sweet
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-carb-engines_2%2F1-8l-carb-issues-oil
https://www.mecatechnic.com/en-GB/carburetor-flange-for-golf-1_GC42410.htm
Regional Host NE
Once sorted use a standard carb airbox then make sure the metal steady bracket and rubber bobin mount are fitted at the front of the factory airbox which steadys it to the front of the head. if missing the carb will flop about and split your new rubber flange
thanks for your help guys.
oh is this not the standard carb ??
what it should have is a circular adaptor bolted to the top of the carb so the airbox sits snug, then there is a Z shaped bracket which bolts to the carb (can see it in pic above) with a odd shaped bolt which goes thru the round hole in the top of the airbox into the bracket.
at the front of the airbox you should have a rubber bobbin mount, which sits in a bracket which is then bolted to the top of the rocker cover to hold it all steady
Ive already completed the plate change,
Its a little fiddly but its nice and tight now, another job ticked off, i decided to clean the manifold whilst in that area, i also took the rocker cover off and the cambelt cover, ive rubbed them down and sprayed them, they look great now.
when ive fitted them i will upload some pics
Buy a rebuild kit and take it apart and clean it all up.
Renew gaskets etc.
Common on Land Rovers.
