what is the correct alternator
(In Topic #219300)
hi ladies and gents i want to replace the alternator on my 83 1.8 gti tin top dx engine the one on there a the moment is
a bosch 0120 489 008 009 k1 14v 55a 20 i think it should be a 65 ah could any body tell me if this is correct its probably been changed over the years for the incorrect one
thanks lee
thanks lee
Deep subject,
I can only guide you through your experience.
The 55A was standard over here on the Diesels without a/c.
The 65A was standard over here on the Diesels with a/c
There are a wide variety of choices, 45,55,65 I have a 90A on my Cabriolet.
Some automotive electrical shops can rebuild yours to up the Amps.
I would say the 65 would do your fine, and that if you want to run a large sub-amp and things you may want to up the amperage.
I will tell you that one thing that you want to keep in mind are the condition of your battery to Alternator cable, as well as your Battery Neg to frame and frame to engine cable.
So if you are going to upgrade may I suggest that you replace the battery to frame and frame to engine grounds.
Relaying the Headlights is another great things to do.
thank you for the reply I'm only changing the alternator
because the bearings are noisy but i will look into replacing the wires aswell
https://volkswagen.7zap.com/en/rdw/golf/go/1983-7/9/903-195000/
Depending on year and engine spec, anything from a 45 amp to a 95amp.
65 amp was probably the original spec for an 83 GTi.
I'd suggest upping it if you're replacing it as why not? They cost similar amounts and you'll always have a full battery, especially if you do shorter trips and lots of stopping and starting.
Ian
Ian
thanks ian I've ordered a 65 amp one pick it up tomorrow
