Replace roof skin, anybody done this?
(In Topic #232148)
Morning,
Wondered if anybody here has replaced the roof skin on a MK1? Not sure if it's absolute madness to even contemplate or a sensible way to go?
Black 1984 MK1 Golf GTI Campaign.
I’v seen threads where this is done in here and there appears to be 3 ways it was approached
1 - cut around the flat part of the roof and leaving about an inch. Then weld a profiled sheet back in patiently with hundreds of spot/stitch welds keeping heat and distortion to a minimum.
2 - cut A B and C pillars and weld a new entire top in place. Very precise job needed and some expert welding for sure to maintain strength.
3 - seen one cutting along the gullies and welding back into the gullies. Lots and of prep work to remove seam sealer and I seem to remember this is a folded section of steal so maybe sealer in between the layers.
All looked a pain and needing more skill than I have. That said looked great when finished but everything does in fresh paint. What do they look like 5 years later - have they cracked, rusted or generally gone bad?
If just a sunroof delete then for sure a small panel by a good body shop is viable and some filler work will for sure be needed.
OR - bond on a carbon fibre roof, still a full on job but maybe a little less intrusive
Another alternative that some have done is get a 'webasto' style fabric sun roof from a 90s/2000s Polo or Fiat and install that as a sort period-ish accessory
Yes exactly, the method I've seen used most often is cutting the pillars and then expertly welding it onto the new shell. I wouldn't have even considered this a few years ago but as it's for an (extremely rotten) campaign I have mothballed at my mothers it's essential to keep it a sunroof car. The ideal would be to find a good rolling shell with a sunroof but the chances of finding one of those is slim to zero!Backinblack said
I'm sure I've seen one of those fitted to a MK1 somewhere. As it's for a campaign, and however cool it might look I could 't bring myself to do it hence having to think outside of the box to get a solid shell together - donor non sunroof shell and roof of the campaign mated together.Early-1800 said
was assuming it was to get rid of a crappy glass popup sunroof. You'll be lucky to find a rust free factory sunroof roof
I've done it with a mk2 sunroof, they are the same.
Personally I think a carbon fibre roof bonded on top of existing and painted, is the way forward.
Or cut the roof off and have a cabriolet
I've got a similar job to do on mine to lose a crappy glass sunroof, have got a carbon skin stashed for when I get round to that one.
