Oil pump
(In Topic #234235)
Do you have any recommendations for oil pumps or is the £32 one from heritage parts as good as any?
For a mk1 cabby gti dohc
If I've looked at the same one as you, then Heritage's offering is 'Topran'.
Reputable enough maker and perfectly good stuff in my experience, target the cheaper end of the market and priced accordingly which isn't to put them down in any way for that but equally you tend to get what you pay for.
Is your old pump dead or are you replacing it because of age / mileage for example?
If so and it's the original VW pump and you can, remove it and take it apart before committing to replacing.
There is an excellent walk through on how to do it on this site somewhere. It'll also show you how to check for wear / tolerences etc.
If it is a VW one and there's no reason to replace it I'd keep it in in preference to a lesser quality new one.
I bought a Febi pump for my MK2 simply because it was at the recommended mileage to do so (75000 off the top of my head), but when compared to the existing VW one it was clearly a few notches down in quality,.
I took them both apart and there were already witness marks on the Febi's inner casing caused by the rotors rubbing but none on the original plus the older one was still well with tolerances.
On the other hand I got a Mahle water pump for the same car (out of necessity that time as the original had gunked up) but it was at least on a par quality wise with VW's so not a hard and fast rule.
Shop around if you're needing a new one … just as an example, Autodoc are doing the Topran for under £25 (less post) at the moment. I realise they get a bad press depending on what you read but it's just an indicator of how prices can vary for the same thing.
I'll see if I can find that link and post it up for you.
https://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=1%2F42%2F145
Proper and full diagnosis can save you time and money, so as Early-1800 said above, I'd get a gauge and check the oil pressure before loading the parts cannon!
If you go the Vdo route make sure the gauge and sender are for the same range, 5bar or 10bar
Wheres the best place to connect it to?
