NO OIL PRESSURE AFTER OIL CHANGE WARNING
(In Topic #185987)
I have never had this problem using bosch filters however the muppet at euro car parts told me they no longer sold bosch oil filters (lie) so bought a mann oil filter. The 2 times i have used these filters they have not filled and starved the engine of oil. Both times using these filters I have had to manually prime the oil circuit with the filter off then again with filter in place. I find the quickest way to do this by removing dizzy and with a drill and long bar with a slot to spin oil pump.
In conclusion i think that the mann filter is slightly more restrictive and therefore the pump cannot fill it, i have reached this conclusion as my operating oil pressure is 0.5 bar higher than with bosch filter.
Any thoughts or other branded filters to avoid?
Regards Volkswarren
try it yourself, pop an empty oil pump in a bucket of oil, spin the drive by hand and watch nothing happen. fill it with oil and try again, notice oil pump out the top easily
a tip if you forget to prime the pump/filter is make something up to fit an electric drill which you can pop down the dizzy hole to engage the pump drive and spin it up that way, some have had success with that. leave ignition on and get a helper to watch the oil pressure light, when it goes out you have a head full of oil ready to start
