Need a replacement clutch can anyone point me in the right direction?
(In Topic #202124)
Golf 1.6 GLi running 1800+ gti engineering engine with original gearbox!
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
the 210mm kit is man enough for that one, its handling my 166bhp ABF lump and many higher power/torque applications just fine. generally if you have enough torque to make a sachs kit slip, you're gonna blow up the gearbox soon!
if you have a 200mm kit now you'll need a 210mm 1.8 flywheel to fit the bigger 210mm clutch kit. You may find the 200mm kit is fine for you even, if you know how much torque the engine is putting out you can compare to sachs kits here:#
http://www.clubgti.com/showthread.php?237089
