Fuel Pipes
(In Topic #215049)
Fuel Pipes
Having the car on a ramp would make life much easier.
Fuel Pipes
You'll probably need to cut the old ones off unless you can get the car massively high in the air. As the originals are steel it's not the easiest, I cut them just after the bend under the floor.
Try feeding the new pipes up from where they enter under the floor pan and go up and around the bulkhead. Unless you have a lift you'll have to do it bit by bit bending as you go.
A bit of a cheat is to use longer flexi pipe that way you don't have to feed so much in and around the steering rack.
Expect much swearing and cursing
Enjoy
Ian
