fuel lines
(In Topic #189415)
ive bought a second hand fuel pump and accumulator set up, the lines are in rag order, and ive no lines on the carb petrol tank ,
now the question is, what size petrol lines do i need ? and has anyone got any links as ive no lines to use as references, ( ie internal diameters and required lengths ) as theres loads
also i havent got the mk3 polo lift pump yet so is it feasible to start building it up and feed the lines and do the fuel pump set up at a later date or will there be no room to get the lines done once tank and rear beam is in place ,
thanks in advance
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
Sorry to jack the thread but im at a similar stage with my 20vt, do the 1.3s have a different size original fuel line to the gti's? I have left the original 1.3 lines in mine for the time being as on all the old conversion threads people dont seem to be changing the fuel pipe work?
im intending on using a facet red top lift pump, 1 ltr swirl pot and a walbro injection pump.
Better i find out now then stuffing my engine up!
adam
Guess il have to re think what im doing!
i take it the breather pipes are larger from looking at pics,
yeah i bought a new gti tank but was talked into taking it back by rj as he was saying the swirl pot in them is pants, so im going to run a lift pump and a 1lr external swirl pot
I'm 99% sure what I've said is right but hopefully someone will be along to correct me if I'm wrong!
i havent got a large plastic thing with 4 connectors on it mate
just a fuel pump and accumulator and related holders and brackets, the lines of which are either snipped or perished
the accumulator bracket keep hold of will be handy for making up your swril pot bracket
Good place to buy fittings and hose from. I bought the yellow nylon hose and re-did the fuel hose on my Caddy with it.
1987 Caddy 1.6Turbo Diesel-GTD
Instagram: Cavscp
Instagram: Cavscp
thanks for the link
