Advice Needed for Indicator issue
(In Topic #167314)
indicators not working
I need some help.
my indicators have stopped working. the hazard flashers work ok, but the indicator light on the instrument cluster is always half illuminated, and when i try to use the indicators they dont flash but the light on the cluster lights up.
i have purchased a new hazard flasher switch and the problem remains.
any ideas what could be doing it?
Mk1 Clipper
www.pcperfect.co
www.pcperfect.co
Still playing up.
Will have another 'root' around and see if i have pulled any cables
thanks
Mk1 Clipper
www.pcperfect.co
www.pcperfect.co
If you want the PSD Boot Sticker file, it's here: Boot Sticker
Push hazard switch in half way, do they start working?
im going to have a play tommoz to try and sort it.
Its Doing my Head IN
Mk1 Clipper
www.pcperfect.co
www.pcperfect.co
Website Manager
Richievr is spot on. There is a single wire to the hazard switch that is often pulled off when you pull the switch out of the dash, it drops down and shorts to the dash metalwork and then blows a fuse.
Worth disconnecting you battery before you go routing for it as almost certainly you will blow a fuse otherwise.
Mk1 Clipper
www.pcperfect.co
www.pcperfect.co
GTI Campaign Helios Blue, Going back Standard
GTI Campaign Schwartz Black shouldn't have sold
GTI Mk7 Performance pack Daily drive
Polo 1.4sel Sunset Orange The Wife's
Triumph Tiger
Triumph Tiger
Many thanks all,yep it was a rotten fuse
Mk1 Clipper
www.pcperfect.co
www.pcperfect.co
