93mk1 troubles?
(In Topic #207195)
93mk1 troubles?
One of the most expensive things to replace properly inc headliner, interliner and the padding.
Plus the rusty rear window frames.
Check for leaks on the hydraulic roof system.
Often joints leak and there's a common issue of the reservoir cracking around the mounting bolts.
Might just save a lot of time, money and aggravation.
We'll give you an honest unbiased opinion based on the pictures and information you can give up.
(even then it's our rough opinion and no a guarantee)
We do it fairly often and I've never known of a case of another member nicking a car from under someone!
Good luck with the search and don't worry you'll find the right one or should I say, he'll find you.
