2k paint query
(In Topic #234195)
Clear coat or not?
I'm painting my cabby La5e Maritime blue Mipa brand I have the paint a few years now.Painting the car went on the long finger. I've painted the wings and boot lid .Now I'm having doubts as to whether I should be spraying 2k clear over the blue? I thought the blue was the finish paint , solid gloss is that what it's called?Any panelbeaters/ spray painters out there answer my questions . Much appreciated . Thanks
The question is did you buy single stage or two stage paint.
Single is paint and clear in one product.
Two stage is Color, and a clear coat on top.
The paint shop never mentioned me needing a clear coat that's for sure . . I would imagine clear would be applied wet on wet over colour . So I don't want go any further til I'm 100 pc sure. . Thanks for reply👍
If you've bought the clear over base (cob) version, you should find that the base coat goes Matt as it dries. If direct gloss then it will have build and gloss from the spray gun .
The base coat is mixed with a solvent only,
Assuming you're using 2K (two pack) the solid colour ( direct gloss) is mixed with a hardener as well as some solvent, and will stay shiny when dry.
Generally these cars were painted in direct gloss if a solid colour, and clear over base system only if it's a metallic colour.
Hope this helps
Hope this helps
