15" Wheel options running 20mm spacers
(In Topic #223743)
Would anyone happen to know what 15" wheel options I would have on my Van? I'm running 20mm spacers to enable calliper clearance as I have 256mm Wilwood Calipers fitted.
The rear arches have no lip now and are flush.
Thanks in advance for any input.
You should be fine with pretty much any 15"wheel with a width of 6.5" to 7.5"
You'll need something along the lines of about ET55 with a 20mm spacer on the front. Assuming you're going to be running a 175 tyre on a 7" rim. This will actually give a position of ET35 which should clear the front arch ok. You might be ok with a ET50 or even ET45 wheel, but I'd stay clear of anything with a smaller ET.
Ideally you could do with a staggered set otherwise you'll be needing to run a 40mm spacer on the back to push the back wheels out enough to fill the arches.
Have a play on this thing
Alloy Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Just remember that the effect of a 20mm spacer is to effectively reduce the ET/offset by 20mm. So if you find a wheel with an offset/ET of 32 works, the wheel you will need will have to have an ET of 52.
Hope that makes sense.
Ian
Ian
Thank you for that'd the link is really helpful.
I was hoping to run a 195/45/15
I ran 185/45 on 15x7s and am currently running 195/45 on 15x8's on et25 but its very tight to the shock.
I actually changed from coilovers to shocks to gain inner clearance.
You may get away with an et40 on an 8 as you have no arch lips but it'll be snug,
Personally I would stagger a set of 7s on front and 8s on rear
Current rides:
