golf mk1 ultimate spec as new must be 1 of the best out ther
(In Topic #128695)
golf mk1 must be one of the best cars out there only can be described as mint,spec as follows;
engine,
tsr ulitmate slick 50 head with shrick 296 cam,solid lifter,matched inlet and exhaust manifold,runninig on single 45 carb very rare,solid lifter,head bolt nut conversion,2000 cc bottom end all bought new cost best part of £4000 new 130 bhp at the wheels.
gearbox.
5 speed close ratio with 4:8 final drive and quaife lsd.
suspension.
bilsteins coil overs on front proper group A,koni on rear with proper springs,eibach front and rear anti roll bar.quaife quick rack with corsa electric colum fitted.
brakes
16v servo,256 front groves discs with audi 2.2 calipers and new carbon loraine pads,disc rear beam with separate calipers for hyd handbrake,a.p valve ,hyd handbrake.
shell
mint must be 1 of the best out there finished in black magic,fully seam welded,safety device cage bolt in ,omp suede stering wheel,omp bucket seats,harness,all fuel and brake lines inside,alloy sump guard,carbon tank guard,comp engine and gearbox mounts,fully fused and realayed,terratrip 303,plus loads more to much to remember,this must be 1 of the best built mk1 out there lovely car.
mint mk1 shell fully seam welded,plus loads more to much to remeber
£5000
tel keith 07855861459
engine,
gearbox.
suspension.
brakes
shell
£5000
