1983, Black Mk1 Golf, White Teledials, Custom Interior . .
(In Topic #134595)
For sale is my mk1 golf. Had this car almost 3 years now, started life as a standard 1.3 driver but since then it has undergone a big block engine change, re spray and many other modifications. It's a lovely car to drive, handles amazing and pulls really well. But really need a more economical car now due to increasing my commute and fancying a change. Was For a straight sale £3250 - Now reduced to £2250 due to insurance running out very soon.
Engine :
- 1588cc FR engine, complete with twin choke zenith pierburg carburettor compete changed
- New cambelt, tensioner and auxiliary belt
- Full service including new oil 10/40 semi synthetic and engine oil flush, air filter , fuel filter
- New triple tip spark plugs, rotor arm, distributor cap
- mk1 gti ignition coil.
- New fuel lines and vacuum hoses
- Full coolant change
- mk2 16v radiator and fan and thermo switch
- mk2 16v coolant reservoir coolant system water hoses changed as appropriate
- New water pump and thermostat.
- Throttle cable changed choke cable removed
Full big block chassis conversion including welding of offside chassis engine bracket.
- Engine mount changed for big block engine with poly-urethane insert.
-Gearbox mount changes for 020 box with polyurethane insert
-Front and rear gearbox mounts changed for big block engine/ 5 speed gearbox
Transmission and Drive train :
- FD 5 speed mk1 gti gearbox with flywheel and clutch.
- Full 5 speed gear linkage conversion and gearbox linkage conversion
- 90mm gti mk1 driveshafts and gti mk1 hubs with bearings.
- New clutch cable and new speedo cable
Chassis :
- Poly bushed control arms
- gti anti-roll bars fitted with necessary chassis brackets.
-FK Highsport Coilovers
-White Porsche teledials with nearly new toyos
Brakes:
- Audi 80 256mm front calipers and carriers,
- Pagid fast roads brake pads
- Zimmerman 256mm cross drilled front discs.
- Corrado g60 brake servo conversion
- Golf 16v 22mm master cylinder
- New brake fluid
Exhaust :
- 1.6 mk1 manifold , down pipe and full exhaust system changed, new rear silencer.
Exterior:
-Respray in straight black May 2010
-Chrome side and sill trims
-Full chrome window seals
-Rear screen louvre
-Crystal cross hair headlights
-Full GTI arch spats
-All red rears
-Smoked front indicators
-Pressed plates, comes with original dealers plates also
Interior:
- Fronts - Rs Turbo Recaros retrimmed in black leather and tartan centres
- Rear - Mitsubishi Evo 8 rear benched trimmed to match
- Brand New Newton Commercial Door cards front and rear
- Fully soundproofed
- Black Kenwood headunit which sounds great and fits nicely in with the dash
Full cobra cat 1 alarm / immobiliser fitted also.
2 months MOT and 1 months Tax.
100_0558 by welsh-mk1, on Flickr
100_0562 by welsh-mk1, on Flickr
100_0559 by welsh-mk1, on Flickr
100_0567 by welsh-mk1, on Flickr
100_0569 by welsh-mk1, on Flickr
100_0564 by welsh-mk1, on Flickr
100_0565 by welsh-mk1, on Flickr
100_0573 by welsh-mk1, on Flickr
Located in Newport, South Wales.
More Info available from my project thread,
http://www.edition38.com/forums/index.php?showtopic=252711&hl=gus%20the%20golf&st=0
More pictures on request, questions by pm please.
Alex
Engine :
Chassis :
Brakes:
- New brake fluid
Exhaust :
Exterior:
-Rear screen louvre
-All red rears
Interior:
Alex
