2 cabrio gti's
(In Topic #163947)
As title, 2 gti cabs.
Both manual hoods, some good bits on them such as chrome trim bumpers, 100mm shafts etc
Located in Aylesbury
Hi
were the front indicator lenses clear on either of em?
Cheers, Paul
Cheers, Paul
No sorry they are early ones
Okey dokey
Engine bay loom mark?
Only needed to to extended mine and renew old/beoken wires so was looking for cheaps
Have you still got the dizzy it's to fit 1990 1.8 gti injection
Are the driveshafts the later post 84 shafts if so how much mate
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
PM'd about front strut.
Yes I have dizzy, 100mm shafts and suspension.
Will pm those that had messages me already.
Hey there, do you still have the interior mirror available? I'm also after the gear linkage heat shield that bolts onto the steering rack? Let me know if you have these, many thanks ash
Hi
I am looking for the rear drum brake spreader bars that go between the shoes.
Am after the Pair.
Am after the Pair.
Any chance either of them is colour code LA7Y?
1985 Cabriolet GL
Not sure mate, never known of any shaft difference other than 90mm or 100mm cvs.
I'd guess they are the ones you need as 100mm are all the same
The later cab 85 onwrds are slightly shorter by about 20 mm … Im using standard 100mm ones now but the passenger side inner cv pushes in on itself at an angle because its too long… I search on here and found that rubjohnny and a couple of others say its because you need a post 84 cabrio shafts that sre slightly shorter but until then i didnt know they were different but it makes sense why mine are at such an angle … They were perfect with the 020 box
Never heard that before?
Best to pop over and we can check them out
Scrub that Mark my mistake ..shouldnt believe all you read lol especially coming from youngsters..
Double checked with Rubjonny yesterday and as we thought no difference..my problem is car too low making shafts sit at bad angle…
Save me money and spend it on seals with you instead lol
Cheers anyway John
Cheers anyway John
Hahaha, fair enough. Didn't think there was any difference.
Have you got the fuel sender unit still.
Hi there do u have the plastic part at the top of the door card drivers side in black it for a sports line golf if so how much posted to n ireland
thanks
thanks
colin
Any Chance you've got a locking handle for the roof for a 92 Rivage. Mine snapped off when I closed it today.
