Windows and winders very stiff anyone recommend a solution
(In Topic #163597)
I have rebuilt my car and its going back together. Can anyone recommend a way to get the windows to be more freely moving as they are very hard to wind up. Have destroyed 2 window winders prior to the rebuild but now i need a solution.
Please helpcf_emoticons__BangHead:
Twitter Manager
but as already mentioned clean/grease the mechanism first.
grease in the tube worked a treat.
Anyone know should there be a window glass channel at the lock end of the door???? as mine has never had one on both sides and when i wind the window up to top o have to make a slight adjust ment with the winder for it to fall into the correct position. Not a biggy just find it weird??
Tapped the metal holder at the bottom a couple of mil then got some 3 in 1 oil inside by taking off the top hockey stick and accessing it from top.
Now slides up and down effortlessly.
It hardly takes any time at all now to shout abuse at corsa drivers.
Thanks for the tips guys.
i pressed the little red button
