window alignment
(In Topic #115817)
window alignment
When the front window is correctly aligned, how far in front of the B pillar should it sit? On my passenger side, the seal on the B pillar is showing about 1/4 - 1/2 inch but on the driver's side, which I KNOW is out of line as, when you wind it down and then try to wind it back up again, it sticks, the seal does not show at all. The glass is almost touching the B pillar. Is the amount of seal showing on the passenger side what I should be aiming for.
cabrio?
window alignment
yes should have said!
yeah you should be able to see a little of the b pillar seal, generally i try to shove the window as far forward as i can into the front slot seal, seems to do the trick. main problem i had was the passenger glass bending inwards too far and catching on the B pillar seal as it wound up, took me a lot of swearing to get it right
window alignment
Thanks and, yes, sounds familiar!!!!
Hi there,
When you say:
I have the same problem, what did you do exactly to rectify?
When you say:
Under the door there are adjustment bolt.
These adjust the fore aft motion of the glass.
The height can be adjusted by altering the bolt which is behind the door cards.
as above, took me ages to get it right i have a feeling something was damaged inside the door or something. i eventually got there but it was making me tear out my hair by the time i was done. driver side i had no such problems!
